Cutting Mortise and Tenon
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=19051
Author:  SkyHigh [ Sat Oct 04, 2008 8:24 am ]
Post subject:  Cutting Mortise and Tenon
How do you guys cut your mortise and tenon? I saw a Sylvan Wells article but he is using table saw which I don't have.
Is there a simple and accurate way of doing this without a table saw?
Thanks, David
Author:  Brad T [ Sat Oct 04, 2008 8:57 am ]
Post subject:  Re: Cutting Mortise and Tenon
I use the tablesaw, but I imagine you could do the tenon with a good handsaw. If I were to do it, I would make my mark with an exacto knife, and clamp a block on the line as a saw guide, carefully cutting to the proper depth. I'd use a good backsaw or a Japanese saw to do it. Just my 2 cents. Someone who has done this should chime in shortly.
Author:  Ennis Guitars [ Sat Oct 04, 2008 9:27 am ]
I do it the way John Mayes does it, with jigs.
